C-175 Pistons
GSR
Does anyone handle 3.750 bore pistons to fit a Farmall C-175? Stock stroke, looking to pull sleeves out. Thanks
let's see an oliver is 3.75 with a 2.187 compression height and a farmall 350 is 3.625 with 2.5 compression height . you could end up with 215 cu inches real easy . put 25 cc dome on that piston and your good to go at 10.2 cr. should get around 60 hp. in my opinion .
the compression should be 2.312 not 2.187 and that will change the numbers somewhat . they wouldn't let me edit my post .
