37 Unstyled JD A Rims HELP
First, I am new to the pulling community. I bought a 37 Unstyled John Deere A bored .045 over. Once I got it home, I looked over it more in depth and found a small crack on the outer hub that the spokes connect to. Not trusting to weld cast iron, I have decided to have a friend build me a pair of 5 spoke rims. Before he builds them, I need to figure out how to mount them to the tractor.
ANY IDEAS OR ADVICE?
Thanks
9 Bolt 10 spline hubs
12x38 rims
Why not put a set of axels from an A 1940-1942 they will go right in as long as you get the bull gears also, then you can use the pressed steel nine bolt hubs which are rather easy to get ahold of. Other option I have made several sets of hubs that use the ten spline tapered hub and have the nine bolt pattern Also there are some nine bolt hubs that fit ten spline axels but expect to pay up pretty good for them. $500-$900 range is what I've seen them going for
