ih 301 crankshaft
super6
Hi everyone my question is, has anyone used c153 rods with a 2.060 inch rod journal for a offset grind in a 301. I was told that these rods would work good and would stand up better than the farmall C rods. My machinest is wondering if the journal is to small. I will be running 2600 RPM and wondering if it will sand up at that RPM. Any info will be helpful thanks
I assume you would use standard C153 rod bearings? Are the rods the correct width on the big end to fit the C301 crank pin, or do they need to be narrowed?
Sounds like you are on your way to getting things together?
rods are pretty close to same a touch narrower. ya the motor is under way. I am using standard bearings
