Front aluminium rims 5 or 6 lug light n narrow for a friend
Real Racing www.realwheel.net makes a 6 bolt that will fit on the stock pattern.
If you are wanting to go to a 5 bolt, you need a different hub. You could go to a custom built pedestal (lighter) with a 5 bolt hub and then any 5 wheel (lots of options) that has the correct pattern will mate up.
Kelly Baldwin. 315-705-5735
