426 in a D17
VicS
Location
SE Il.
All day on the clutch. And a little grinding. Think motor will slide in now. And throwout bearing hit the fingers
I have put new plates and ramps in. If won't', guess will weld two inter gears together. Or look for a D21 gear reduction. Will they work. Hope to eventually have 200 HP. :)
I have never seen inside a D21 center housing, figured gear reduction was almost the same. I do have e gine in. Clutch even workes. Now for the front axle.
Another picture. I am black! Took another hour of grinding. Also need a couple helicoils on bottom two bolts.
