Mid Atlantic Antique Tractor Super Pull 3-21-2015
CLIFF S
Info
Cliff S
In addition to the above classes and divisions we are offering two no speed limit classes for the following high horsepower tractors. All Safety equipment required!
1. Interstate Non-Turbo Rules tractors
2. Super Antique Tractors-If you don't meet the Interstate rules-you are considered Super Antique
3. Small Block V-8 Tractors
4. Big Block V-8 Tractors
All four divisions will pull together at the same time, with the same tractor weight and the same sled settings. Results will be separated! You can compare with each other, yet the results are separated!
6000lbs pulling at approximately 11:00 am
6500lbs pulling at approximately 2:00pm
(quoted from post at 21:13:15 03/08/15) Whats the cost to watch
Unless something has changed, there is no admission charge for spectators. Only Hook and insurance fees for pullers. I am sure donations would be welcome to help cover costs. This pull makes a whole lot more fun than money.
