262 gleaner build
tpuller13
New User
just bought a 262 gleaner gas to put in a cockshutt 40
whats the best power build on thetha cheap side. or if it
runs good do i need to? thanks
If you can find propane pistons to put in it, it will give you a 40 psi boost in compression and a good 10-15 hp boost if you do some carb work to feed it. I've seen guys make 95 hp on them with stock cubes. Only difference in the propane pistons is the wrist pin is lower so that it pushes the piston higher. I've been told those pistons are hard to come by these days so it may be cheaper easier to have a set made or stretch the rods.
I don't carry gaskets but these pistons will get you up around 11:1 compression.
If interested let me know the bore size you want and compression (can make whatever)
$900 with pins, rings and shipping
Keep us up on the build. I'm doing the same thing. Exempt I already have a 262 in it. Have to pull back out to fix a internal problem.
Thanks jd b looks like what i want. I will get it
tore down and let u know. Do u carry rings for those
pistons. Thanks for your help
