Conicville, Va Antique Pull
JDMarkb
Saturday Oct 4th at 2pm there is a antique tractor pull at the Conicville Fire Hall in Conicville, Va. There are 3.5 mph uncut tire and 6 mph any cut tire classes. Weight classes from 2500lbs and up. Good food and clean bathrooms at the firehall. This is there last antique pull of 2014
ncdiesel48, They pull up to 9000lbs and have classes every 500lbs. The address is 763 Conicville Rd. Conicville, Va.
Thanks you for the reply, we used to go there probably 15 yrs ago, do you have a set of rules? Hitch height and such? Thanks in advance.
(quoted from post at 14:27:17 10/02/14) Thanks you for the reply, we used to go there probably 15 yrs ago, do you have a set of rules? Hitch height and such? Thanks in advance.
I don't think they have a post set of rules.
20" high and 18" back If I remember right.
Standard stuff, 10% RPM's, 3 MPH limit...
I can't remember if they have a fast class
