I called about an oliver 77 I saw on craigslist. Owner says it has a small oil leak at the rear of the engine. He thinks it's the head gasket. Is that possible? I would think it would more likely be the be the valve cover gasket. I don't know much about olivers. Thanks in advance.
more than likely valve cover gasket as you suspect, could also be rear main seal, which is common, they used a cork seal, dripped a bit from new on if not pre-soaked in oil before installing...
