seals, gasket
haggerty60
New User
Iam doing a brake/seal job on a naa left side. Along with the cork gasket between shue pivot plate and tin seal retainer assembly,do you also add a paper shim gasket? Iam using Smiths tractor axle repair page and IT fo-19, still want to be sure. Also will use ultra blue permatex per Smiths brake/seal job. Thanks for the help, hope to be able help someone else here somday. Bob
