8n, 12v, side distro
it seems on my last plowing/discing session that the solenoid shorted and engaged the starter at some point. it started smoking when i shut the tractor down.
got the starter off and inspected it and it had some white "calcification" looking char on the center post and one of the very worn brushes even came off in my hand as i removed the center portion.
Question is, how do you tell if its worth spending the time rebuilding? IE is there a go/ no go check before i spend time replacing the brushes with a rebuild kit?
also, any suggestions or tips for the rebuild process?
Thanks,
Cam
Thanks,
Cam
