WindrowFarm
New User
Hi all,
I have a 1968 MF 165 Diesel with an independent PTO (no multipower, so just a small auxiliary hydraulic pump for the clutch pack.) Had the PTO clutch pack go bad on me last year (of course right in the middle of first cut), and a local dealer fixed it for me with refurbished parts (new was quoted at a $10,000 repair bill - got it down to $3,200 with used/refurbished - still hurt.) This job replaced the clutch pack and aux hydraulic pump, and sent out the main hydraulic pump to have the PTO bushing (which had disappeared) re-installed. The mechanic also said he machined some burrs out of the PTO shaft where it goes through the main pump.
The PTO has worked for the past 9 months since I got the tractor back. However, there are a few strange things that are causing me to hold my breath about it:
1) When engaging the PTO under load (mainly the baler), I get a short hydraulic grunt/squeak from under the seat (where all the magic happens) about 75% of the time. This didn't happen before. Happens at all rpm's, though I always try to do it at an idle just to minimize shock.
2) *Only* with the new (to me) tedder I purchased (a 4-head Vicon RS410T), when turning corners with the PTO engaged I get a strange clicking/crunching sound under the seat, again where all the magic happens. Sort of rhythmic, but in short bursts. No loss of PTO power or anything other than the sound, but certainly doesn't sound right. I worry it's some kind of side-to-side slop where the shaft was machined and it goes through the main pump, but I'm just talking out of my butt about that. And no sign of that sound running any other piece of equipment, or when driving straight with the tedder.
3) Toward the end of last fall, I started the tractor a couple of times to find that the PTO would turn on with it (attached to a brush hog), even though the lever was in the off position. A similar thing has happened this spring with the fertilizer spreader. It seems to happen more when the tractor is cold, and I have yet to have it happen when hooked to an implement under higher load (like the mower or baler), but then again haven't used them much since last fall. Unsure if this is a related to the above, or if it's a matter of the PTO lever being worn / not quite disengaging fully. (Roll pin doesn't look too worn, but there is a little bit of slop. Not sure if there is any adjustment to be made there.)
Phew, sorry for the novel. Anyone have any experience with any of the above, or thoughts on whether I ought to be prepared for it to give out any given day? I'm afraid if the PTO gives out that's curtains for this tractor - love it, but can't afford to be sinking several grand into it every year. But would also like to sleep better at night if folks think this isn't another catastrophic failure waiting to happen.
Thanks!!
Thanks!!
