ffemt27chev
New User
Hi, I purchased a Deere B Sunday and have some issues I need to fix.
First, the high low range won't stay in low range and the lever is in the way of the clutch lever when it's in low range.
I opened up the gear and believe the detent for this is not adjusted properly to get the gear in when the detent falls into place. Doe anyone know how to adjust this? The transmission looks good as far as not having shaving everywhere.
How much slop should be in the gear if I jack it up and spin the tires?
I have a bearing/grinding noise coming from the pulley/clutch. How do I get into it to see where that noise is coming from?
The steering has play in it. Took the shaft covers off, it looks ok and the bearings are in place. How can I fix this?
[/img]
[/img]
