4030 hydraulic remotes revisited
wolfman
I switched the two hoses (on the same set of remotes) and the hydraulic remotes worked like new. Made this old man think every time I opened the baler gate as to which way to move the lever.
Your test(switching sides with hoses) indicates that 1 of the 4 valves in the scv isn't seating properly to hold the pressure. I always wondered why JD engineers made the internal mechanisms so complicated and difficult to adjust valve clearances.
