posted about welding the cracked gearbox a few days ago. Took it apart and another piece fell off. Nice rake so decided to bite the bullet a get a new one. The owners manual says to keep the gearbox full to a certain point with 140 gearlube. but going to the IPB on the Nh parts site, printed across the picture of the gearbox it says use grease not oil. The casting is the same except its not drilled and tapped for the fill plug. must have had too many run dry. I put a grease fitting in the cover so it shoots onto the gear. I saved the old casting and will try to weld it sometime. Probably like plowboy suggested heating it first. I remember seeing the blacksmith weld big cast gears by heating them in the forge, welding them hot, and then burying them in lime to cool. Arlen thanks for the offer of your spare casting . One of your neighbors will probably need it, or if you got rid of it, 2 weeks later you'll need it yourself.
