ih no. 15 hay rake
8N Tim
I have an IH #15 side delivery rake that im trying to rebuild and i cant seem to find out what size and type drive chain i need and what the chain tensioner looks like because they are both missing. If anybody has any pictures or knows what parts i need let me know.
I do not know the model of the IH rake I have and use is but if you can post a picture what i have maybe close if not the same
Pictures
Looks like the one I have other then mine is in usable shape. The chain I would have to check as for size. As for how you tighten it well when I got mine it had a rotten piece of 2X4 oak bolted on it and I took a good 2X4 oak piece and installed it say 10 or so years ago and it is still in place. Throw me an e-mail and I'll try to get a picture or 2 and also maybe a chain size
2050 chain and as old says just a wood block tightener. I always pull chain off mine when I travel any distance on road. Just rebuilt gear box on mine.
As was said,#2050 chain. Oak is the best thing for a tighener. However,a chunk of pine 2x4 will suffice. Just cut a (approx) 3" circle,or egg shape. Drill a hole and install. Soak it with oil to make it last .
