Air cleaner
I would stay away from Fram filters.. I would go to Wix, Napa, Baldwin, or Hastings before I would use Fram. I have seen a enough engine failures and problems with the use of Fram filters.
I am unaware that Fram has a replacement for the Kawasaki air filter. Rotary, Stens, and probably Oregon have replacements they claim are equivalent.
I always installed the OEM part. Yes, it is expensive, but far cheaper than a new engine. You might get a water cooled Kawasaki for 3K.
Sir The freight line that I worked went to Fram filter because they are cheap but after 3 DT 466 failed and it was because of filters they went back to fleet guard and had no more problems. I personally used a Fram in my Buick and it idled with oil light on and I put a Wix on it and light went out and never comes on. I also used a Fram air filter that was for my Ford pickup truck (Extended service filter) It sucked the outer foam filter into the pleated paper of filter. They gave me another one and it did the same thing in less than 3.000 miles. I went to a Hastings and had no problems. So don't tell me Horsehockey.
Air filters are cheap, go to your local lawn and garden dealer and get the correct one or get one from an actual OEm supplier such as stens or rotary
If you dont have any luck locally give me a shout I am a Dealer for the top brands of aftermarket and OEM brands
