ourdogblue
New User
I've had my 801 Powermaster for over 20 years and never had any serious trouble. She does a lot of mowing. I check the fluids, change oil, and lube and local dealer has had to bring it in to his service shop and do a tune-up and minor repairs like a power steering hose leak maybe every 2-3 years. I'm probably at least the 3rd owner. Now there is a significant oil leak around oil pan gasket. I got a new gasket and some RPV and took off the oil pan. Only 19 of 20 bolts were in. One had been sheared off and the end is stuck in the engine block, up front where it goes into the block and not thru the side flange. There was no gasket, just a layer of gasket-maker or RPV which peeled off easily. So a previous owner broke a bolt, put it back together with goo, and it's worked fine for many years. My question: should I spend time trying to get the broken bolt out so I can have all 20 in or leave it alone and just try the new gasket and RPV? I realize this is a pretty trivial thing compared to the major repair work discussed in this forum, but I'm a newbie here, and would appreciate any advice. Thanks much.
