watersteps
Here is a question for those of you that have split a Ferguson Tractor and had a need to pull the flywheel. Engine, Z134 Continental, is there an o-ring that goes in the flywheel before the flywheel is mounted on the crankshaft.
I was cleaning up my flywheel and I found either packed dirt or broken up rubber in the recessed area of the flywheel. This is a single clutch set-up.
Thanks for any help you can offer.
