Char Lynn hydraulic pump specs.
Wondering if anybody has pressure and flow info for a Char Lynn hydraulic pump? The pump mounts on the pto and was last used on a super w6 to run a loader. I'm wondering if it will run a small pulp loader. Any info would be great.
Thanks.
(quoted from post at 13:03:11 09/17/14) From the spec sheet 12gal and 1000 psi rpms not over 750 I also have the parts manual. Model E-600 POWER PAC
Okay, that's great, I'll check the requirements of the loader. The flow should be good but the pressure might be low. Thanks a lot for the info.
