dynahoe 190
sticky1
New User
serial number 2000....E
Does anyone know the master cyl part number?
does the brake cyl take hyd fluid or dot 3 break fluid?
The diagram looks like the master cyl is tied to the hyd res.
Not 100% sure but I think the master cylinder was made by Wagner,see if there is a part number stamped on it,if not measure the bore and contact them for a dealer near you,they may be able to supply a repair kit that would get you out of trouble,I don't know about the fluid but a lot of machines do have the brakes hooked to the hydraulics,if it has remember the engine has to be on low idle when bleeding.
AJ
http://www.wagnerbrake.com/products/brakes/wagner-hydraulics-hardware.html
do you know if there is a way to toe a 190 without hurting the hydrostatic pumps ?? Like disengage something???
If you have the dual master cylinder w/ air actuators, the Dorman part number is DOR M661 which is available and fairly inexpensive. I bought a pair from a local distributor for less than $70 each
