pressure regulator valve question
daveminn
Just put a new charge pump on my 850 c case crawler because I was having problems with the oil in my torque heating up after a half hour of pushing.Problem solved with the temp but the pressur valve still wants to run high and kick oil out of the torque after a half hour or so of use.My service manuel does not explain much on how to check over the pressur valve but I notice that the bobbet in the valve does not move freely like I think it should.Can this be the proble or what else should I check.As always THANKS for any help you can offer!!Dave A
