Spark plug wire removal from Magneto
Old Allis
New User
I am trying to replace the spark plug wires on an Allis B, but they don't want to let go at the magneto cap end. I don't want to pull too hard in case something breaks. Any help appreciated.
Sometimes the soft boots get stuck. You can try running a small screwdriver around them to break them loose. Otherwise, just keep pulling.
AaronSEIA
I'm guessing the brass terminal are full of corrosion. Some WD40 might help. twist and pull on the wires. The terminal might come off. most times they can be removed by picking on them with a sharp rod.
